You can search for an item and organize
			lists in the XCO
			user interface. You can group records based on the pre-defined criteria that vary for
				different windows.
Use the Previous (<) and Next (>) icons to scroll
				through the lists.
				To search for a record in a
					page, enter a search attribute such as object name, IP address, location in the
						Search
					field and click Search (  ). ).To clear the search, click
						X in
					the Search field.
				To group records in a page,
					select Group
						By and choose an attribute.
				To clear the grouping, select
					the Clear
					option. The list is organized by
					the grouping attribute you selected. The headings are collapsible.
				To filter records in a page,
					select Filter (  ) and
					choose the filter attribute. ) and
					choose the filter attribute.To clear an individual filter,
					click x
					for the appropriate filter. To clear all the filters, click Clear All
					Filters. The list is organized by
					the filtering attribute you selected.
